3
This discussion topic has been answered Discussion topic: Q box
This message was authored by: archie+murray
Q box
Frequently my Q box will freeze off usually requiring a reset when first switch ing on in the morning.
Avatar for archie+murray
This message was authored by: archie+murray Answer
Re: Q box
Thanks for responding,from 7 am,disconnecting and plugging in again after 30sec resets the box.
Re: Q box
Hi @archie+murray   What time in the morning, to rule out a problem with your Standby settings?
Re: Q box
This message was authored by: Mar73
Re: Q box
I recently changed my broadband to EE, This unfortunately resulted in my Sky Q box, loosing it's signal to the other 3 tv's
Having had EE engineers at 3 times, is appeared that the problem was my main Sky Q box. I contacted Sky, who sent me a new box. Same problem. Every night, my Sky Q box would cut of the signal to my other tv's, resulting in me, turning every box of and resetting the system.
Finally I had a Sky engineer answer my problems and it was very simple
1) go to settings and press
2) scroll down to preferences, press
3) change your setting from eco to active.
End of problem all tv's are now working perfectly.
But when you turn of your tv at night ensure you press your Sky q box to stand by
Happy days
Martin
