Discussion topic: BBC channels not working
Message posted on 31 Jul 2024 02:38 PM
None of my BBC channels are working on either box, have reset etc and cannot get them to work
Message posted on 31 Jul 2024 03:09 PM
Re: BBC channels not working
What's happening when you try to watch 101 for example? Any error message on the screen?
Message posted on 01 Aug 2024 07:56 AM
Yes every BBC channel states there is an issue with my skybox and signal
Message posted on 01 Aug 2024 08:10 AM
@Tom19881
A message displaying ”no signal” tends to be from your TV.
Any message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
