Discussion topic: BBC channels not working
This message was authored by: Tom19881
None of my BBC channels are working on either box, have reset etc and cannot get them to work
Re: BBC channels not working
@Tom19881
What's happening when you try to watch 101 for example? Any error message on the screen?
Avatar for Tom19881
Yes every BBC channel states there is an issue with my skybox and signal
@Tom19881
A message displaying ”no signal” tends to be from your TV.
Any message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
