5
This discussion topic has been answered Discussion topic: Audio Description On Some Channels
This message was authored by: bt1512
Audio description is on some channels even though setting is "off"
I've rebooted SkyQ box as mentioned in another similar thread for at least 4 minutes.
However, AD is still on some channels.  No rhyme nor reason to which ones tho.
Started this morning, noticed it on Ch4 while watching Cheers. Thought it might have gone away by now. Driving me nuts!!
Any help?, please
Re: Audio Description On Some Channels
@bt1512
Have you tried turning the audio description ON then turning it off again?
Any help?, please
Hi @bt1512
Make sure you turn AD off in
Home - Settings - Accessibility
Avatar for bt1512
Level 2 icon
Hi, oldfella
thanks for response, just checked and it's showing as "off"
Brian
Avatar for bt1512
Level 2 icon
Still happening this morning, no suggestions have worked.
Do you think I might need a new Sky Q box?
@bt1512
Avatar for bt1512
Level 2 icon
Hi Daniel,
I turned AD on, then rebooted Sky Q box.
Then I turned AD off, this appears to have worked 🤞
Many thanks for taking the time to help.
Brian
