8
This discussion topic has been answered Discussion topic: Apps disappeared from mini boxes
This message was authored by: Stellag
Had to reboot the system today and all is reconnected fine - SKY Q main box and 2 mini boxes for multi room.  However, on the min boxes there is now nothing showing on the Apps menu. This includes Netflix which we are paying for, ITV X etc.  Have tried the Settings/001/refresh apps process. Left it for over 5 minutes as suggested before returning to watch tv. Just checked (2 hrs later) and there's no progress showing. I read somewhere it could take up to 24 hours for the apps to refresh - is this right? Should I be seeing any progress on the refresh process or do I just wait for 24 hours?
This message was authored by: Quoman7 Answer
Re: Apps disappeared from mini boxes
@Stellag wrote:
Thanks - will give it a go but I'm still not clear whether the booster connects directly to the bt hub or the sky Q box?  At least you used to have superpowers!
@Stellag The booster connects to the main SKYQ box, through their own wifi mesh.
hi @Stellag
Best to Wait a while
You could try rebooting again.
First try rebooting the main Q box and then when this is completely back up and running reboot the minis
Reboot the minis as above.
Avatar for Stellag
Level 2 icon
Did all that but now having trouble getting the sky q box connected to the bt router. We have a sky booster so it may be something I'm doing in the wrong order. When do you switch the sky booster on, and do you connect it to the bt router using the wps system or to the sky q box? Idiots guide would be very welcome! TIA
Hi @Stellag Try rebooting your router and SKY booster by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, and do the same with any Mini boxes
Avatar for Stellag
Level 2 icon
@Stellag i'm guess the booster is to extend the signal to a mini box in which case the booster will connect to the main box then the mini will connect to the booster
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Stellag
Level 2 icon
Thanks for the replies - it's so much easier to ask other sky users than phone and spend ages either on the phone or running round from room to room!
This message was authored by: Robert6
Do the apps reappear after 24 hrs
