Discussion topic: No output from Sky Q Box after resetting
This message was authored by: GaryMilkins
Ive suddeny lost connectivity between my Sky Q  Box and Sky Q Box Mini - when disconnecting and restarting the main Sky Q box I get the initial start up screens then nothing after that and TV simply says 'no output' Is my Sky Q box dead?!
Re: No output from Sky Q Box after resetting
Hi @GaryMilkins
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
