1
This discussion topic has been answered Discussion topic: Additional Q box faulty
This message was authored by: PaulSimpson
The second Q Box is stuck in standby
Re: Additional Q box faulty
Hi @PaulSimpson
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Hi @PaulSimpson
