1
This discussion topic has been answered Discussion topic: Problem with satellite signal on many sky channels
This message was authored by: Kareng1963
After talking with you on many occasions we still have problems seeing many sky channels can you help please
Re: Problem with satellite signal on many sky channels
@Kareng1963
You aren’t contacting Sky Customer Services by posting on here. This is primarily a customer to customer forum.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
@Kareng1963
