This discussion topic has been answered Discussion topic: A message asking me to insert viewing card
Message posted on 31 Aug 2024 05:11 PM
A message has come on screen asking me to insert the viewing card. I thought there was an inside the box otherwise we don't have one
Message posted on 31 Aug 2024 05:43 PM
@Jak1525 your viewing card is on the right hand side of the box near the front only a few millimeters of it will be sticking out if you push it in it should then spring out take the card out and give the chip a wipe with a soft dry cloth then re-insert the card making sure you put it in the same way it came out then push the card in until you hear a click
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
