Discussion topic: 2nd multi room box not working
Message posted on 04 Jun 2024 11:16 AM
My 2nd multi room box is not working, it shows the red light but will not switch on, we have tried reactivating it , but still will not work
Message posted on 04 Jun 2024 11:22 AM
Re: 2nd multi room box not working
Hi @JJ556
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 04 Jun 2024 11:54 AM
Thank you we are trying to reset it now, how can we find our security code?
Message posted on 04 Jun 2024 12:03 PM
Thank you, everything is back up and running
Message posted on 27 Jul 2024 08:29 PM
This worked for us too. Thank you.
