Discussion topic: Sky box not connecting to wifi
This message was authored by: Adele89
We have sky broadband. The sky q box isn't connecting to the WiFi. The TV is connected
Avatar for Adele89
Level 0 icon
Re: Sky box not connecting to wifi
We have done the troubleshooting it says to do and it's not worked
Have you exactly followed the procedure below @Adele89
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to Sky  router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
