7
This discussion topic has been answered Discussion topic: 2160p 10 bit - supported? 4K LG G4.
This message was authored by: slipd
Hi guys,
I was looking at my box settings recently and I notice that I was only set to 1080i... Pretty sure I'd set this to 2160p previously, but hey ho. Anyway, I can't appear to set the res to 2160p 10 bit, despite it being supported. Best I get is 8.
Thoughts? I'm using very decent 8K HDMI cables to my devices.
Thanks.
Avatar for slipd
Level 4 icon
This message was authored by: slipd Answer
Re: 2160p 10 bit - supported? 4K LG G4.
Think I've sorted it... it applies anyway 😂
It was just a colour tweak in settings.
Thanks everyone.
@slipd wrote:
Hi guys,
Thanks.
hi @slipd
Check the settings in your TV's menu for the HDMI you are using, I can't remember the setting specifically for LG but look for options like Deep color, Enhanced (I think that is Sony)  - although I think most modern TVs now default to these it is worth checking
Hi @slipd   What is the length of the cable?
Avatar for slipd
Level 4 icon
1.8/2m I think.
Avatar for slipd
Level 4 icon
Just looked at my HDMI cable specs: 8 and 12 bit are supported. No mention of 10. Could it be that possibly?
@slipd
Any cable which supports 12bit (which would have to be HDMI 2.2) will also support 10 bit.
@slipd as @nigea99 stated you need to find the deep color setting on your TV and activate it then you should be able to use 10bit
Avatar for slipd
Level 4 icon
Thanks everyone.
