Discussion topic: 2160p 10 bit - supported? 4K LG G4.
Re: 2160p 10 bit - supported? 4K LG G4.
@slipd wrote:
It's a tough one then, I'm not sure what else I can try? @MightyQuinn, we're you using LG? Any special settings or anything?
I have never had an LG but I believe the key setting (as I mentioned earlier) is Deep Color.
TBH if you have a v1 box & you can set it to 2160 8 bit I doubt if you would really see the difference in 10 bit - you would probably need to have identical screens next to each other to spot the very subtle differences in colour palette  the 10bit gives
Although I used 10 bit with my v1 box and my Panasonivc TV I could not tell the differnce wetween 8 bit & 10 bit (I now have a V2 box so get HDR)
The big difference using 10 bit with HDR (v2 & V3 boxes only)
