Discussion topic: Sky q broken
Message posted on 23 Nov 2025 04:32 PM
Sky q broken
Skybox will not come on
Message posted on 23 Nov 2025 04:36 PM
Re: Sky q broken
Hi @Dwain88
Assume this is your main Q box?
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
If you have to order a new main Q box this usually means a doorstep swap.
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
