42
This discussion topic has been answered Discussion topic: 2029 - changes to Sky ?
This message was authored by: Wibbly-Woo
I understand that by 2029 - Sky will no longer be supporting Q - instead we will all have to use "Streaming"
Something that I am not looking forwards to a bit - as at the moment Q is used to record certain  programs every week and watched at our leasure
I assume that there is a way to run two TV's at the same time on different channels using Stream ?
I don't believe that it needs two "pucks" ?
This message was authored by: Invisiblename Answer
Re: 2029 - changes to Sky ?
@Wibbly-Woo wrote:
@Chodley You  are the experts
But you're the one saying you are
I am just another Sky customer!
Hi @Wibbly-Woo
You may not believe it but afraid it does.
To run stream on two non glass TVs you need two pucks and the whole home subscription in addition to your monthly package subscription
Avatar for Wibbly-Woo
Level 4 icon
.. which no doubt costs a fortune ?
What ever happened to cable links ?
You'll trip over them.
RF retransmission over coaxial cable from a Sky+ box was never capable of real HD, let alone UHD.
In theory it's possible to split the HDMI output from a Stream puck to two television sets, subject to the maximum cable length limit of the chosen resolution.
Level 4 icon
@SKY1992bf
Costing how much ?
ie) To simply allow watching TV in two seperate rooms
There's a one-off charge per Puck and a monthly charge of £15 for a Whole Home subscription (often discounted).to allow viewing on more than one Puck
Sky has always charged more money for that, through Multiroom, Multiscreen and now Whole Home.  Being able to access low resolution cabled RF-out from a Sky+ box was a technical anomaly on hardware which is now at least a decade out of date.
Level 4 icon
@TimmyBGoodYou'll be telling me next that you can see the difference between UHD and HD on a 38" screen .......and that it is worth paying a premium for it ??
@Wibbly-Woo
38" is a computer monitor, and yes, at typical computer distance 4K makes a difference even on a smaller panel.
If you choose to watch a monitor from across a room, that's not the same circumstances.
Level 4 icon
@TimmyBGood
My CRT TV doesn't do HD !
Unbelievably - it does actually have a USB port on it though no HDMI
How are you running 2 TVs off Sky Q without a mini?
Level 4 icon
