This discussion topic has been answered Discussion topic: 2029 - changes to Sky ?
Message posted on 23 May 2025 01:38 PM
I understand that by 2029 - Sky will no longer be supporting Q - instead we will all have to use "Streaming"
Something that I am not looking forwards to a bit - as at the moment Q is used to record certain programs every week and watched at our leasure
I assume that there is a way to run two TV's at the same time on different channels using Stream ?
I don't believe that it needs two "pucks" ?
Message posted on 27 May 2025 12:00 PM
@Wibbly-Woo wrote:@Chodley You are the experts
But you're the one saying you are
Message posted on 23 May 2025 01:42 PM
Re: 2029 - changes to Sky ?
Hi @Wibbly-Woo
You may not believe it but afraid it does.
Message posted on 23 May 2025 01:44 PM
@Wibbly-Woo wrote:I understand that by 2029 - Sky will no longer be supporting Q - instead we will all have to use "Streaming"
To run stream on two non glass TVs you need two pucks and the whole home subscription in addition to your monthly package subscription
Message posted on 23 May 2025 01:56 PM
.. which no doubt costs a fortune ?
What ever happened to cable links ?
Message posted on 23 May 2025 01:58 PM
@Wibbly-Woo wrote:What ever happened to cable links ?
You'll trip over them.
Message posted on 23 May 2025 02:25 PM - last edited: 23 May 2025 02:29 PM
RF retransmission over coaxial cable from a Sky+ box was never capable of real HD, let alone UHD.
In theory it's possible to split the HDMI output from a Stream puck to two television sets, subject to the maximum cable length limit of the chosen resolution.
Message posted on 23 May 2025 03:40 PM
Message posted on 23 May 2025 03:46 PM
There's a one-off charge per Puck and a monthly charge of £15 for a Whole Home subscription (often discounted).to allow viewing on more than one Puck
Message posted on 23 May 2025 05:52 PM - last edited: 23 May 2025 06:18 PM
@Wibbly-Woo wrote:
ie) To simply allow watching TV in two seperate rooms
Sky has always charged more money for that, through Multiroom, Multiscreen and now Whole Home. Being able to access low resolution cabled RF-out from a Sky+ box was a technical anomaly on hardware which is now at least a decade out of date.
Message posted on 26 May 2025 03:34 PM
@TimmyBGoodYou'll be telling me next that you can see the difference between UHD and HD on a 38" screen .......and that it is worth paying a premium for it ??
Message posted on 26 May 2025 03:37 PM - last edited: 26 May 2025 03:38 PM
38" is a computer monitor, and yes, at typical computer distance 4K makes a difference even on a smaller panel.
If you choose to watch a monitor from across a room, that's not the same circumstances.
Message posted on 26 May 2025 04:09 PM - last edited: 26 May 2025 04:10 PM
My CRT TV doesn't do HD !
Unbelievably - it does actually have a USB port on it though no HDMI
Message posted on 26 May 2025 04:30 PM
How are you running 2 TVs off Sky Q without a mini?
Message posted on 27 May 2025 08:01 AM - last edited: 27 May 2025 08:02 AM
