Discussion topic: No satellite signal
This message was authored by: Davidlfc123
No satellite signal
The sky system has intermittent signal issues.  Last night no issue, today no signal and or pixelated picture which freezes.  Each time l reset the system and eventually after about an hour it reverts back its normal use.  This has lasted 3 months and extremely frustrating particularly at the cost paid for the poor service
Re: No satellite signal
@Davidlfc123  A "No Satellite signal" message has nothing to do with broadband as your channels are delivered by satellite and not related to broadband.
Your post has been moved to the correct board.
Please follow the steps in this guide Having a problem with your TV signal? | Sky Help | Sky.com | Sky Help | Sky.com
@Davidlfc123
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
