06 Aug 2023 09:11 AM
I would like the indoor camera to be inactive when it's not armed, but currently you can go into the app and view through the camera at any time. This is a little creepy.
How can I get it to deactivate when it's not armed?
07 Aug 2023 04:05 PM
Posted by a Superuser, not a Sky employee. Find out moreThere is no way to do this currently.
All I can suggest is through the Sky Protect app, you send a support request asking for this feature or call the Sky Protect number to request it as a future feature.
10 Aug 2023 07:28 AM
I suppose you could turn the motion detection off, turn the sensitivity down turn off noise detctioned and sensitivity:
Bit of a pain every time thought:
10 Aug 2023 09:46 AM
Thanks, both. It seems crazy that this can't be turned off. I wouldn't have plugged it in at all if not for the fact that it's necessary for the sensor bridge if you want to use any of the sensors. I've turned it around to face the wall, but have found that the light on the sensor bridge is incredibly bright.
@Chimpishuk It's not the motion alerts that bother me, because they don't happen when the system is disarmed. It's the fact that it's constantly recording. There's something unpleasant about the idea that I could call the camera up on the app and see whatever my kids are up to in the lounge, or vice versa. It's intrusive.
10 Aug 2023 12:48 PM
I see what you're saying, at the end of the day your private conversations are being held somewhere is SKY's proprietary cloud but it's not recording 24/7. That's not how it works. It will record based on alerts. Personally I wouldn't have SKY's camera recording my living room..mine is in my office because I have epilepsy and work from home. My wife can keep an eye on me aa some of my seizures require a paramedic.
Alternatively. Stick a load of bluetack over the mic and a towel over the camera. Admittedly not an elegant solution.
Is there a specific reason you decided to use the camera in the lounge? I've got two bay window contact sensors plus a motion sensor. The exterior of the bay windows is covered by door bell cam + additional cam
11 Aug 2023 11:38 AM
Nope, no specific reason for it being in the lounge other than that it has to go somewhere. I wouldn't be happy with it anywhere - it's just a lack of privacy.
05 Nov 2023 07:23 PM
@DuncanKent do you own the items under your name? If so do you have 2 indoor sky cameras? Really want ti add additional camera to the home and 6 more contact sensors
08 Nov 2023 09:18 AM
No, these are just the ones that came with the kit.
