This discussion topic has been answered Discussion topic: Doorbell charging issues
Message posted on 26 Oct 2023 06:41 PM
I've had my doorbell on charge for 48 hours after it died completely. The battery is now on red. When I plug it in I get a solid yellow light not the flashing blue and yellow as described on the instructions. Anyone had these issues and got a fix?
Message posted on 25 Jun 2024 12:07 PM
@Tony123412234 wrote:Our doorbell is not 5 months old yet, doesnt take a charge, tried charging it with its power set to off and also tried with the power set to on.
Either way it works for about 5 mins then stops.
This has worked for others in the past;
Try turning the doorbell off, via the switch next to the usb socket under the flap at the back.
Leave off for at least ten minutes.
Turn the doorbell back on and straight away using the supplied usb cable connected to the chime, charge the doorbell for at least 8 hours or overnight.
Message posted on 26 Oct 2023 10:06 PM - last edited: 26 Oct 2023 10:13 PM
Re: Doorbell charging issues
Try via the app doing a reboot of the doorbell, when it's not connected via usb to the chime for charging, then try recharging again.
A solid yellow normally means it's not connected to the chime.
Yiu could try re syncing it, make sure when syncing the doorbell you keep it pressed until it clicks.
If none of that helps, try resetting the doorbell by pressing reset for ten seconds and then resync with chime.
Message posted on 29 Oct 2023 09:06 AM
i had the vsame problem mine would not chargeleft over night. then this morning i pushed the on / off swith on back of the doorbell by the charging point to off left it for 10 sec and pushed it back to on and it is now charging
Message posted on 18 Dec 2023 11:03 PM
got the same issue
Message posted on 25 Jun 2024 10:51 AM
Also when it was working if someone rang the bell, it wouldnt ring on my phone for about 30 seconds so by the time i got to the door the person / delivery would have gone.
Sky this tech is substandard, any explanation or can i cancel my policy due to your product not working.
Message posted on 17 Jul 2024 12:11 PM
for the first time ever mine charged overnight I turned it off plugged in waited 9 hours it was 98% I left plugged in and switched off till next day it dropped to 91% so it's improved only thing out of the tech pack that works
Message posted on 22 Jul 2024 09:14 AM
Mental worst system ive ever used ,,,, records the crap i dont want to see ,.. then the other day i had someone knock on my door then try the handle, i happened to be in .. did it record it lol course it didnt🤣🤣🤣 whats this now it doesnt charge,.. when have you ever had to turn something off then on to charge crap crap crap crap crap crap crap crap oh and the other camera lol lags and is crap
Message posted on 26 Aug 2024 06:46 AM
Tried recharging the battery for 8 hours and still it says 6%. Should the switch on the back of the chime be on or off during charging ?
Message posted on 26 Aug 2024 07:15 AM
@Mellors wrote:Tried recharging the battery for 8 hours and still it says 6%. Should the switch on the back of the chime be on or off during charging ?
The switch on the back of the video doorbell needs to be on when charging.
If you find the video doorbell is not charging correctly.
Turn the video doorbell off using the switch and leave off for at least ten minutes.
Turn the switch back on and start charging again.
Message posted on 14 Sep 2024 04:10 PM
Completely agree what a load of rubbish and a waste of money...
Had it on charge for over 48 hours still flashing blue and yellow can't sync it
When I do get it to work and someone presses it the delay is shocking...
Message posted on 15 Sep 2024 03:45 PM
Re: Doorbell Signal and Camera Issues 🤬
I received mine a few weeks ago and I'm already on my second doorbell and chime which is hugely frustrating! I can sometimes see a huge drop in both the battery and also the signal! When I go to view outside it slowly buffers up to 85% and then says no signal and needs rebooting, as you can imagine I'm paying for a service I cannot use! I have my own entrance to a second story flat and have the chime directly plugged into the router as stated. Sometimes I get the chime when someone rings the doorbell and I often get alerts of people at my door or near by. Has anyone else had these issues? I'm ready to cancel my policy and send the whole lot back to sky as I feel like it's 3rd rate equipment. As you can imagine this is highly frustrating and when I am disabled and want piece of mind if I fall that I can alert paramedics if I have a fall and give them my key safe number. Any helps and tips would be warmly received please ❤️
Message posted on 03 Jun 2025 07:42 AM
Same problem and looking below it doesn't look like we're the only ones! Guess this is what happens when you get something for free. I'm currently trying the turn off for 10 minutes trick. The last thing I want is for the battery to go completely because it is then an utter nightmare to get synced again ....
