6
This discussion topic has been answered Discussion topic: Want to keep old sky number
This message was authored by: Neasy
I'm an existing customer of sky and got new phone and SIM with them. I want to keep my old phone number but unable to use PAC code. Can Anyone help
This message was authored by: SKY1992bf Answer
Re: Want to keep old sky number
@Neasy  If you have a current sky sim and have a new data plan on a different sky sim then you need to either
transfer the number you want to keep to another payg provider then back to the correct sky sim
or
ask sky to transfer the new data plan to your existing sky sim (but this is at sky's discretion as there is no obligation)
or
This message was authored by: ANTSMAN
This seems pretty crazy and wasn't explained to me when I ordred a new SIM.  So I have to leave SKY to keep going with SKY?
Hi @ANTSMAN  yes if both sims are with sky then you can't port from one to another, either call sky on 150 to see if they can give you the new plan on your old sim (dont be surprised if they say no) or you need to port to another network then back onto the new sim.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
The normal procedure is to simply not order a new dataplan and move the old SIM from old to new phone.
Sounds like you've ordered an additional plan (so you're paying for 2).  As noted, you cannot use a PAC code within a network.
The SKY team told me I needed to order a new SIM with the new phone.  Apparently, I was misled
You don't need to.  As stated, if you do and activate it then you will have 2 plans and a new number.
Possibly.  Get back on to them...  (Calls are recorded if necessary)
