Discussion topic: Voicemail Help please
Message posted on 22 Jun 2024 11:56 AM
help with how to decrease ring time before it goes to voicemail please.
Message posted on 22 Jun 2024 12:09 PM
Re: Voicemail Help please
I believe the maximum is 30 seconds.
To change it press: **61*759*11*XX#
Replace the XX's with the amount of time you want the phone to ring for before it transfers calls to voicemail.
E.g. **61*759*11*25#
That would change it to 25 seconds.
Message posted on 22 Jun 2024 12:28 PM
thx. I tried that but it does not work
Message posted on 22 Jun 2024 12:50 PM
error messege shows
call forwarding
when no reply for All speech services
Connection problem or invalid MMI code
