362
This discussion topic has been answered Discussion topic: Phone not working in calls or out calls just disconnecting
This message was authored by: Claire666666
Can't make calls on my mobile
I can't make or receive calls currently on my Samsung Galaxy A55 5G. It simply isn't connecting
Re: Can't make calls on my mobile
Hi @Claire666666  try activating flight mode for more than 10 seconds then turn flight mode off.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
This message was authored by: Alex8900
Can't call or receive calls
My partner myself and my dad are not able to call in or out we are all either sky but can call other networks
Re: Can't call or receive calls
Hi @Alex8900  try putting your phone in flight mode for at least 10 seconds then put it back to normal.
This message was authored by: K93
Re: Phone not working in calls or out calls just disconnecting
Issue started today.Tried toggling airplane mode. Didnt work?
Did you leave flight mode activated for at least 20 seconds @K93  ? Worked for me.
This message was authored by: Cookie47
Both mine have been back on for about an hour, let's see for how long
This message was authored by: Jellypickles
Just had aeroplane mode on for 30 mins before trying to use my phone, still nothing for the 2nd day running now
This message was authored by: Grief83
Turn off WiFi calling and it's fine.
Don't know why this is an issue, but I turned it off and straight away calls are working fine.
Thanks grief83 you are a life saver as I finally have a working phone
This message was authored by: Mary311
Re: ‘Call failed’ calling out and ‘Incorrect number’ calling in.
Had the same issue for the last few days.  Take the sim out, wipe over the gold contacts, replace sim.  I worked a treat, phone now making and receiving calls again.
This message was authored by: Mcreed
There something wrong with my phone
It not call out
Re: There something wrong with my phone
Hi @Mcreed  try turning on airplane/flight mode in your phone settings for at least 20 seconds then turn flight mode off.
This message was authored by: Shaunna89
Can't ring out or receive calls
My phone won't ring out it don't even make a sound when I try to ring out and can't receive calls in it just says you have dialled an in correct number
This message was authored by: Stacey0
No call out or in
I cannot make or recieve calls but can text and use data
Answered - Go to Answer
