Discussion topic: Technical issue when upgrading
This message was authored by kimimpossible This message was authored by: kimimpossible
Im trying to upgrade my ipad because it says im able to swap, but it keeps coming up with a technical issue when i go to add to basket, it says this :
"Technical error
It's not you, it's us. Try refreshing the page. Or use the link below to start again"
I have tried refreshing , deleting cookies and same message. However when I try to upgrade mobile it goes through fine.
This message was authored by 63johnw This message was authored by: 63johnw
Re: Technical issue when upgrading
Hi @kimimpossible  you will need to call sky for help with this. Call on 150 from a sky sim.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
This message was authored by Ava+lily This message was authored by: Ava+lily
Im trying to upgrade my mobile phone but it keeps coming up with technical error! i need to get this done in time for my daughters birthday as its a present!
@Ava+lily
Have a read of the post from @63johnw as it will apply to you as well.
