Discussion topic: Sky roaming help
Message posted on 07 Jul 2024 01:51 PM
Sky roaming help
Hi I spoke to sky and asked for roaming date fir 10 days up until 16 th July that was agreed and now I've been told ends to day's I cannot put back on
Message posted on 07 Jul 2024 01:54 PM
Re: Sky roaming help
Sky don't do roaming packages for longer periods. Depending on where you've gone it's a £2 charge for each 24 hour period.
Message posted on 07 Jul 2024 01:57 PM
Thank you , how do I activate it ? I was told 10 days
Message posted on 07 Jul 2024 02:01 PM - last edited: 07 Jul 2024 02:02 PM
That might suggest the culmulative £2 per day charge has now reached your spending cap.
https://www.sky.com/help/articles/sky-mobile-spend-caps
Message posted on 07 Jul 2024 02:04 PM
You just need to make sure roaming is turned on in your phone settings and you have set a spend cap sufficient for £2 a day. As soon as you send a text, make a call or use some data it kicks in. You haven't said where you are so be aware it's only in certain countries that it works like that. If you're in a 'rest of the world' country then the charges are much higher.
Message posted on 07 Jul 2024 02:05 PM
How do I re activate it daily then please ? Why was this not explained ? Thanks for help
Message posted on 07 Jul 2024 02:52 PM
@Leesabell wrote:How do I re activate it daily then please ? Why was this not explained ? Thanks for help
It's 'automatic' on usage. (Subject to spend cap)
Message posted on 07 Jul 2024 02:55 PM
See my post immediately above your last post.
