Discussion topic: Removing parental control
This message was authored by: Ash74
I'm trying to remove parental control and my card details are not being recognised
Re: Removing parental control
@Ash74  Are you using a credit card?
debit cards won't work
Avatar for Ash74
Yes I'm using a credit card and it keeps saying use a valid card number
Give Sky a call on 150 to see if they can help you with this. You might have to wait until tomorrow now.
@Ash74
In addition to using a credit card, the only other way is if you have signed a credit agreement with Sky, then they will already know you are 18 or over so if you call them later they can deactivate this for you.
