Discussion topic: Remote managed iPad
Message posted on 11 Jun 2025 07:32 PM
Remote managed iPad
Hi
needing some help, or just a little advice.
I've just purchased a second hand iPad 5th generation off a online marketplace.
Advert looked good, the photos showed the iPad had been factory reset & ready to start brand new usage.
When I got home & started the set up, I inputted my WiFi password, then got a remote management page, managed by Sky & can't go any further with set up.
Is this something that can be rectified by Sky, or have bought a glorified paperweight.
I know it's an old iPad & probably not worth it, but I've paid for now.
Message posted on 11 Jun 2025 07:37 PM
Re: Remote managed iPad
Whatever that page you are seeing is, it isn't something that Sky can or will be able to help you with.
Message posted on 11 Jun 2025 07:59 PM
Hi
many thanks for the reply.
If the iPad is remote managed by Sky & Sky won't be able to help, who could help?
Message posted on 11 Jun 2025 08:04 PM
Have you spoken to whoever you brought it from ?
Message posted on 11 Jun 2025 08:08 PM
@markie69 A remotely managed device is likely to have been a business provided ipad or enrolled into BYOD (Bring Your Own Device) option at the sellers workplace, they would need to get Sky to unenrol the device from their IT system.
Message posted on 11 Jun 2025 08:13 PM
Can you access the settings menu @markie69 ?
- Open "Settings" App.
- Scroll down and then tap on "General" section from the left menu
- Scroll down all the way and then tap on "Device Management"
- Then tap on "MDM Profile"
- Then tap on "Remove Management"
- If it ask for a passcode, Please enter your passcode
- From now on device will no longer controlled by a remote person
The above steps will remove the remote management control from the device.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 11 Jun 2025 08:16 PM
Hi
unfortunately I can't access anything on the iPad, until I pass the sky remote management page
Message posted on 11 Jun 2025 08:18 PM
Hi
The young lady I purchased the iPad from is not answering any messages on the market place
Message posted on 11 Jun 2025 08:19 PM
Hi
how do I get Sky IT team to un-enroll the iPad, is there a contact for Sky IT?
Message posted on 11 Jun 2025 08:29 PM
Even if anyone could point you in their direction @markie69 i doubt they would help, that iPad will be registered to a company/organisation and that group would need to request any removal.
Message posted on 11 Jun 2025 08:36 PM
@markie69 wrote:
Hi
You can't, please see my previous reply.
Message posted on 11 Jun 2025 08:48 PM
Some ideas here: https://www.magfone.com/unlock-ios/remove-ipad-supervision.html
Hi
Thats why I am trying to contact Sky, as the iPad is registered to Sky, I thought they would be able to in register it from their control
Message posted on 11 Jun 2025 08:59 PM - last edited: 11 Jun 2025 09:04 PM
@markie69 You don't work for Sky, the person who did/does is the one responsible to get it deregistered, assuming they still work there, if not it would have been removed upon account deletion.
The IT team have no responsibility to a non employee.
I'm afraid it's down to the seller to sort out and if they won't then you need to raise it with the site you bought it through.
And TBH this isn't a Sky issue as they did not sell you the device so have no responsibility to sort it out.
I would try the steps in the link posted by @PandJ2020 as this may be your only option now.
