4
Discussion topic: Not registered on network
This message was authored by Tazzj This message was authored by: Tazzj
Not registered on network!!!
Got old samsung a50 & new samsung S20FE5G.....
Cant call out or get calls on new phone...only old phone???
Im confused 😕
Can anyone help me pls.....
This message was authored by caesarome This message was authored by: caesarome Answer
Re: Not registered on network
Is the phone you are having issues on from Sky and if so has it been working previously ?
Tazzj
It's a new sim for a new upgrade mobile... ive tried to activate it with code but still won't work??
If you can't activate it then you will need to call Sky and ask them to do this for you. If your other phone has a Sky sim in it then the free number to use is just 150.
Tazzj
Hi Thanks for your help...
It seems I should have taken my old sky sim out after new sim downloaded my info then put into my new phone!!!
So confusing!!! Thing is I have to open all my apps with passwords before I can use them & not all my contacts have transfered....
