8
This discussion topic has been answered Discussion topic: No signal
This message was authored by: Pat_z-e
No signal
I haven't been able to get a signal on my phone since last night, is there anyone else that doesn't have a signal
Re: No signal
@Pat_z-e
If you contact Sky they may suggest sending you a replacement SIM card in case yours has developed a fault.
Re: No signal
@Pat_z-e
First thing to try is whether any local mast issues show here?
https://www.sky.com/help/servicestatus/your-services/mobile
Remember Sky don't own or maintain any mobile masts so if there is a local mast issue you and others in the area will be relying on a third party fix.
Avatar for Pat_z-e
Re: No signal
Hi thanks for that, I've done all the usual checks and they all seem to be fine, my wife and daughter are on the same network and they're fine, it must be an issue with my phone, I've had it about 5 or 6 years and never had a problem with it, I'll probably have to take it to a repair shop and see if they can work out the problem.
Thanks again Daniel
Re: No signal
@Pat_z-e
Avatar for Pat_z-e
Re: No signal
I never thought of that, thanks I'll give that a try
Avatar for Pat_z-e
Re: No signal
Hi Daniel
Thanks for mentioning about my sim, I would never have thought of that, it was my sim that was the problem and not my phone 👍
This message was authored by: Sue322
Re: No signal
My signal is terrible. If I wasn't on WiFi calls at home. I'm permanently on SOS CALLS. also out and about I only have. One bar if I'm lucky
Re: No signal
@Sue322
Any relevant information showing on this link
https://www.sky.com/help/articles/service-status-sky-mobile
It may disclose a nearby mast issue. Remember Sky don't own or maintain any mobile masts so if there is an issue you and others in the area will be relying on a third party fix.
This message was authored by: murty9999
Re: No signal
No signal at all for a few days now! Reported it and still no update! I recently moved to sky mobile and I have found there is problems with signal and streaming issue with the roaming data! This needs to improve or come renewal I will be gone!
