10
This discussion topic has been answered Discussion topic: My phone stopped making or receiving calls.
This message was authored by: Ladylouth
iPhone 11. When I dial a number, I hear three beeps and then nothing happens. People can't call me either. Have tried all the suggested iPPhone tips (toggled airplane mode, reset network settings, restarted phone etc.) I have a signal.
Re: My phone stopped making or receiving calls.
It might be a faulty sim so I would try either calling them if you are able to or use the social media links at the bottom of the page to ask them to send you a replacement sim.
@Ladylouth
Are you able to try the sim in another unlocked phone to see it is works because if it doesn't it might have devloped a fault so you would need to contact Sky to ask them to send you a replacement.
Avatar for Ladylouth
Thanks - I tried that. When I call myself, an engaged tone, and when I call another number "Conditional Call forwarding is active"
@caesarome see above
Do you have call forwarding turned on ?
@caesarome No. I checked that, and also blocked numbers - nothing there.
@caesarome Thank you. I will do that. Really appreciate your help. Will let you know if this resolves it.
This message was authored by: SiobhanMcD
I'm having the same issue this morning and there are a number of similar comments today . Must be a Sky issue
@SiobhanMcD Mine is back working now, as suddenly as it stopped.
@caesarome Problem resolved itself, as suddenly as it started!
