Discussion topic: Mobile issues in scotland
This message was authored by: Scotspaul
Mobile data is down In my area in Scotland, Sky were as useless as an ashtray on a motorbike
Moderator Notes: renamed to better reflect issue in post
Re: Cannot make calls from France
@Scotspaul
I've moved your post to its own thread as it had nothing to do with the problem facing the OP and others in FRANCE.
Any relevant information showing on this link?
https://www.sky.com/help/articles/service-status-sky-mobile
Avatar for Scotspaul
Of course it's similar problem when you have outages worldwide and blaming a mast, it's lies
@Scotspaul
The other we're having problems whilst roaming abroad. You're having an issue in the UK.
So, is anything showing on that link? Remember Sky don't own or maintain any masts.
edit: I've requested staff change the thread title to reflect the issue you're having.
Sky website status says a mast is down..   5 days and using a good search engine like duckduckgo shows it's all over UK and Europe,  it must be a big mast lol
@Scotspaul
So a local mast to you in Scotland has a fault therefore you'll be relying on a third party repair.
