Discussion topic: Incoming calls
Message posted on 30 Oct 2024 03:50 PM
Incoming calls
My iPhone 16 only rings 3 times before going to voicemail how do I extend the amount of rings
Message posted on 30 Oct 2024 03:56 PM - last edited: 30 Oct 2024 04:24 PM
Re: Incoming calls
Hi @Steve19671 try this.
Change the length of time the phone rings before going to voicemail
To change it, dial: **61*759*11*XX#
Replace the XX's with the amount of time you want the phone to ring for, before it transfers calls to voicemail. The maximum time you can set it to is 30 seconds.
E.g. **61*759*11*25#
That would change it to 25 seconds."
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 30 Oct 2024 04:01 PM
Re: Incoming calls
Hi John I just tried that but came up with an error page🤷🏻♂️
Message posted on 30 Oct 2024 04:03 PM
Re: Incoming calls
Are you replacing the two Xs with the seconds you want ?
Message posted on 30 Oct 2024 04:06 PM
Re: Incoming calls
Yes mate I put all the numbers in I assumed after I press the call button would that be correct ?
Message posted on 30 Oct 2024 04:08 PM
Re: Incoming calls
Open dialler then don't press the call button and then put the sequence in @Steve19671
Message posted on 30 Oct 2024 04:12 PM
Re: Incoming calls
Once the sequence is entered then press the call button @Steve19671
Message posted on 30 Oct 2024 04:23 PM
Re: Incoming calls
Sorry @Steve19671 looks like it's changed since I last posted on the subject. Try this.
https://www.sky.com/help/articles/sky-mobile-voicemail
go to voicemail greetings settings and help and there is the current sequence listed there.
open dialler then enter the sequence then press call. (XX being the number of seconds).
Message posted on 30 Oct 2024 04:27 PM
Re: Incoming calls
Hi mate it must be me tried what you said still no joy put the code in then done the steve19671 on keypad then pressed the call button said unable to take your call must of forgot to tell you I'm a techno- phob😁
Message posted on 30 Oct 2024 04:28 PM
Re: Incoming calls
Message posted on 30 Oct 2024 04:39 PM
Re: Incoming calls
Thanks for your help mate
Message posted on 30 Oct 2024 05:02 PM
Re: Incoming calls
@Steve19671 wrote:Hi mate it must be me tried what you said still no joy put the code in then done the steve19671 on keypad then pressed the call button said unable to take your call must of forgot to tell you I'm a techno- phob😁
Not sure what you mean by "done the steve19671" ?
have you found the sequence in the link above ? Skys system won't let me post the actual numbers here.
Message posted on 04 Aug 2025 10:46 PM
Re: Incoming calls
I had this problem with my iphone. Always a mad scramble trying to answer phone within 16 seconds before it went to voicemail. I rang Sky and they instructed me to tap a code into the phone's keypad and how many seconds I wanted it to ring for. Then you tap the green phone icon. As simple as that, they said, but it made no difference. I spent hours and hours trying to solve this problem. Eventually found the answer -
On a recent iphone update they introduced a new feature called Live Voicemail, which means you can listen to the message while it's being recorded and answer the call if you choose, instead of the old style voicemail where you can only hear the message after it's been recorded. The Sky code to extend the ring time will only work if you turn off this Live Voicemail feature. Go to Settings and scroll down to the bottom and tap Apps, then Phone, then Live Voicemail, turn that off. Now, your phone will ring to your chosen seconds and record the old style voicemail message, where you 'dial' 751 or 759, or whatever it is, can't remember, and the BT-style-robot-voice will lead you into the message left for you.
It seems to be a problem that has stumped a lot of people, so I hope that helps..
Message posted on 03 Oct 2025 01:55 PM
Re: Incoming calls
Hi - THANK YOU so much for your post! Finally, I have managed to change my IPhone 16+ to 30 seconds ring!!! I had tried typing in all the codes I found online and it would always say there was an error. After trying and googling for a couple of hours, I resigned myself to the fact that I'd have to spend an hour on the phone with the lovely Sky CS. So I'm so glad I read to the bottom of this question and found you!! I've now turned off my Live VM and it now rings for 30 seconds. Great! But....(oncoming rant)... I don't understand why it's restricting my ring time anyway??!! They apparently invent a new feature, Live VM (this is my 1st iPhone after 25+ years of android so I don't know how 'new' it is. I'm still very much an Apple WIP, so still finding it confusing) and I really loved this version of VM, thought it was brilliant. To now find out that I can only use this feature if I go back to a 15-second ring time before VM, is really annoying. And just stupid. Why can't I have Live VM AND choose my own ring time?!
So I've never been on these forums before. But I just wanted to thank you. And have a rant!! 😂😂 but mostly a thank you. As you have saved me having brain-ache 🤯 THANK YOU! And to everyone else, this method definitely works! And to Apple/Sky - please, please change this! Sky's own Customer service obviously don't know about this, as it sounds like they are still apparently giving out the codes to people, at least they were in August, when your message was posted. Thanks again for sharing, Learning Slowly, you are a star!
Message posted on 14 Oct 2025 03:07 PM
Re: Incoming calls
I'm having the same problem..ie. all the codes on the net to change my ring duration does not work, very frustrating! Anyone know how to solve this issue for Google Pixel 7Pro? I would be eternally grateful! 🫱🏻🫲🏼
