Discussion topic: I have ordered 16promax and it was not delivered and returned from courier to sky
This message was authored by: GOGULAMUDI
Re: I have ordered 16promax and it was not delivered and returned from courier to sky
@GOGULAMUDI
This might have happened if you have failed the second more enhanced credit check that takes place. You can call Sky to find out if this is what has happened as they can answer this for you but as Sky is not allowed to view your financial records they can not tell you why you have failed the check. You might want to look into this yourself by signing up to a site that allows you to view your records, one credit checking site they use is Experian so you could sign up to a free trial with them, just remember to cancel.
@GOGULAMUDI
If what @caesarome has indicated is the reason, any upfront charges you've made should be reimbursed within about 14 days.
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
