Discussion topic: Dubai can’t make or receive calls
This message was authored by G12bey This message was authored by: G12bey
In Dubai can't make calls, sky tells you to call them, I can't make calls!!!
I've tried removing depending cap and all other online advice
G12bey
Re: Dubai can’t make or receive calls
I'm trying to run a business in the UK this is ridiculous
This message was authored by Daniel0210 This message was authored by: Daniel0210
@G12bey
What is happening when you try to call the UK?
Sky mobile is a domestic service so shouldn't be the sole method of running a business while abroad (or in the UK).
▪️I AM NOT A SKY EMPLOYEE ▪️
G12bey
When you need help, how can a business refer you to a community forum rather than help you? Crazy
G12bey
Sky advertise their roaming, so being a domestic service simply isn't true
@G12bey
Domestic as in 'for domestic customers' not for business purposes.
This message was authored by PandJ2020 This message was authored by: PandJ2020
@Daniel0210 wrote:
@G12bey
In the first few lines of the contract it says "Sky Mobile is a service for the personal use of UK consumers only".
I am just another Sky customer and my views are my own
This message was authored by Sherie1 This message was authored by: Sherie1
Can’t call a Uk landline from Dubai
I can't call a Uk landline from Dubai. The network carrier gives an automated message "number dialled not valid. Please check the number and try again"
I have tried numerous Uk landlines and same error message occurs
Re: Can’t call a Uk landline from Dubai
I am using + 44 and dropping off the 0 for the area code
@Sherie1
Someone else had problems yesterday making calls from Dubai.
https://helpforum.sky.com/t5/Sky-Mobile/Dubai-can-t-make-or-receive-calls/m-p/4483951
it might be an issue the Dubai end. Make sure your spending cap isn't too low.
thanks @Daniel0210 ive done all the trouble shooting and I'm on the £2 a day roaming and on the standard £45 cap. I've not made a call yet, so maybe a network issue at Dubai end
G12bey
Message saying not authorised number. In Arabic then English
when someone calls me from Uk, nothing, no dial tone.
borrowed a phone to call Sky twice take you thru the same routine, then simply give up
and to make it clear, this is my personal phone, but use it to be contacted on emergencies. Don't carry business phone on holiday or I'd be on phone all day..
This message was authored by Barty This message was authored by: Barty
Calling uk from Dubai
I'm in Dubai and despite trying every international code combination imaginable I get a invalid number message when I try any uk number . I cannot call the sky helpline either so absolutely screwed! Any advice gratefully received. Thanks
Re: Calling uk from Dubai
@Barty
I have moved you post to this topic where you can see you are not the only one with issues in Dubai at present.
