Discussion topic: Do I need to activate the SIM that came with my laptop? I don’t need it but will it cause a problem?
Message posted on 10 May 2025 01:08 PM
I have just purchased an Apple MacBook Air and had to select a SIM deal as part of the purchase. I chose the one that is £0 a month as I don't need a new mobile deal but do I need to activate the SIM card even though I won't use it? I have tried to do it anyway but the sky system is horrendous and I'm stuck in a loop.
Message posted on 10 May 2025 01:42 PM
Re: Do I need to activate the SIM that came with my laptop? I don’t need it but will it cause a prob
@AliciaH you don't need to activate it, If you don't want it, don't activate it and it'll drop off your account after 31,days
Message posted on 10 May 2025 02:05 PM
You might be sent an email reminding you to activate it but you can ignore this as you do not have to do this.
