Discussion topic: sky q with new vodafone hub can not connect to box to view recordings in skygo
Message posted on 31 Aug 2024 04:47 PM
Sky Q box
Vodafone Powerhub with wifi 6
I have multi room
I can watch live programs on Skygo on windows laptop and android tablet.
Both of these devices do not connect to Sky Q box to watch recordings on Skygo.
I have tried resetting wifi credentials on Sky Q box, but no change.
Message posted on 31 Aug 2024 05:02 PM
							Re: sky q with new vodafone hub can not connect to box to view recordings in skygo
Do you have a multiscreen sub with your Sky Q TV package as you need this on your account before you will be able to connect the Sky Go app to your Sky Q box.
Message posted on 31 Aug 2024 10:35 PM
Yes I have muti room subsription, as stated in query
Message posted on 31 Aug 2024 10:43 PM
Is the option to connect to Sky Go turned on via your Sky Q box and the same setting on the Sky Go app ?
Message posted on 02 Sep 2024 10:38 AM
Thanks for the suggestions.
I have now solved the problem by resetting everthing from scratch.
I am not sure where the problem was
Thanks again
