Discussion topic: Unable to record on sky Q box remotely using sky go app
Message posted on 06 May 2025 02:18 PM
I'm unable to record on my sky Q box remotely using the sky go app. I don't get any error. It asks me if I want to record once or the series and seems to accept the request but then no recording on my box.
It works if I'm on my home WiFi (where I can also see recordings) but not if I'm away from home. I spoke to sky who advised that I have to be on my home network to do this but that contradicts what I've read online!
I've uninstalled and reinstalled the app, checked the software version on my Q Box and I also subscribe to multi-room (which is apparently a pre-requisite).
What am I missing?
Message posted on 06 May 2025 04:12 PM
Re: Unable to record on sky Q box remotely using sky go app
What they told you is nonsense as you should be able to set recordings to your Q box via the Sky Go app when you are away from home so when you are not at home are you on a mobile data connection or perhaps something like a works Wifi one ?
Message posted on 06 May 2025 04:28 PM
It doesn't matter what I use. 5G or another WiFi connection. Always have a good service and can connect to app and tv guide with no issue. It asks if I want to record once or series and then I see the R against the program. Then nothing on my scheduled recording on the actual Q box.
Message posted on 06 May 2025 04:35 PM
This isn't a live chat so replies may not be instant.
Message posted on 06 May 2025 04:43 PM
Thanks 👍🏻
Message posted on 06 May 2025 04:45 PM
Thanks for escalating this. We’ve sent crispy74 an invite to chat.
Please be aware conversations automatically close if there is no response within 48 hours.
Message posted on 07 May 2025 01:10 PM
Message posted on 07 May 2025 01:11 PM
For others experiencing the same issue. Apparently this feature has been removed without communication
Message posted on 07 May 2025 01:18 PM
That is odd as it is working for me. Using mobile data only I managed to set a remote recording to my box.
Message posted on 07 May 2025 06:25 PM
@crispy74 I have Sky Q and just tried it by switching off my wifi on my phone so I was only on my mobile data and was able to set a recording successfully as well
So it is still working
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 07 May 2025 07:42 PM
Beware when you're Q box or app updates then as will stop working !
Message posted on 07 May 2025 08:40 PM
@crispy74 afraid it wont what you have been informed is incorrect.
Mine is on the latest firmware for the Q box (Q310.000.13.00L ) and for the Sky Go app i'm on the latest software version 25.1.1.
Have you tried uninstalling the app from your mobile device then rebooting your Q box then re-installing the app and finally trying to record again to me it seems your Q box is not registering with the app to receive the record command.
The old Sky+ app was really good for checking that it was all registered and the correct viwing card was registered but this app is no longer available/supported
Message posted on 07 May 2025 09:43 PM
I've tried uninstalling and reinstalling the app. I've tried from both my Apple and Android mobiles and it doesn't work on either. Sky Q box on Q300 software version which I was told by sky was the latest version. Sky have basically dismissed my issue.
Message posted on 08 May 2025 11:13 AM
