This discussion topic has been answered Discussion topic: Sky Go still not working on Macbook Pro with Sequoia
Message posted on 22 Jan 2025 10:06 AM
Re: Sky Go still not working on Macbook Pro with Sequoia
Now finally working on about the 10th attempt. Did the same round of deletions as previously but this time it worked,, so assume that Sky have finally updated the Go software to work on Sequoia. Did not need to mess around with 32 bit emulation etc, which in any case does not work in Sequoia, so guessing that Sky have properly updated Go to a fully functional 64 bit app.
Message posted on 22 Jan 2025 04:38 PM
I'm thinking it is a sequoia compatibility issue too. Exactly the same issue on my new MacBook Air M3 which is running Sequoia.
I wonder whether one of the Sky technicians can check this?
Jon
Message posted on 06 Feb 2025 03:58 PM
Worked a treat ! Thanks very much.😀
Message posted on 20 Feb 2025 10:01 AM
Guys, easy fix
I too have a new Mac and was a bit dumfounded while the installer kept running and then closing without actually installing Sky Go.
1) So, first right-click the installer and select 'Show Packag Contents'
2) Open up MacOS folder and launch the installer - this will open a terminal window where you can see the progress of the installer... note when it finishes you will see the message: "installer: This package requires Rosetta 2 to be installed. Please install Rosetta 2 and then try again."
3) Open new terminal window and ype (or copy paste) 'sudo softwareupdate --install-rosetta'
4) once this has installe, re-run the installer, but make sure you select 'Open usiong Rosetta' from the Info window of the installer before you launch.
Hope that helps - worked for me
Message posted on 03 Mar 2025 10:55 AM
Hi. Thanks for the reply.
I followed your steps.
The process completes sucessfully. I have no issues with missing components.
SkyGo still refuses to open when the icon is clicked.
C
Message posted on 03 Mar 2025 11:10 AM
Hi C
Not sure what to suggest mate - did you delete any existing application?
Are you sure, you are trying to open the right app now? Do a search in your finder for Sky Go... i've just noticed my 'App icon' doesnt display in the 'Applications' folder, its in my 'account' folder (users > XXXXXXX > Applications > Sky Go
Message posted on 02 Apr 2025 08:46 PM
Brilliant. It worked for me. Well played & thank you. 👍
Message posted on 20 Apr 2025 11:02 AM
Perfect thank you Rosetta worked for me.
So frustrating prior to finding this solution.
Message posted on 23 May 2025 11:11 AM
Amazing, thanks for the step-by-step guide on how to solve this issue. Have been struggling with this for a while.
Ran through your steps, worked perfectly 👌
Message posted on 25 May 2025 12:32 PM
Worked for me!
Well done for the info, much appreciated!
Message posted on 25 May 2025 06:58 PM
Works!!!
cheers for the assist!
Message posted on 23 Jun 2025 02:15 PM
Didn't work for me I'm afraid.
I have tried all of the suggested fixes and to now avail still have "We are having problems connecting you"!!
This running on new MacBook Pro M4 Pro Sequoia 15.5
Still running fine on my Old Macbook running Monterey and ok also on my iPhone!!
Aargh!
