35
Discussion topic: Sky Go still not working on Macbook Pro with Sequoia
This message was authored by R.W+Laidlaw This message was authored by: R.W+Laidlaw
Re: Sky Go still not working on Macbook Pro with Sequoia
Now finally working on about the 10th attempt. Did the same round of deletions as previously but this time it worked,, so assume that Sky have finally updated the Go software to work on Sequoia. Did not need to mess around with 32 bit emulation etc, which in any case does not work in Sequoia, so guessing that Sky have properly updated Go to a fully functional 64 bit app.
RWilsonL
This message was authored by Jon129 This message was authored by: Jon129
I'm thinking it is a sequoia compatibility issue too. Exactly the same issue on my new MacBook Air M3 which is running Sequoia.
I wonder whether one of the Sky technicians can check this?
Jon
This message was authored by terencelang This message was authored by: terencelang
Worked a treat ! Thanks very much.😀
This message was authored by karlbaker This message was authored by: karlbaker
Guys, easy fix
I too have a new Mac and was a bit dumfounded while the installer kept running and then closing without actually installing Sky Go.
1) So,  first right-click the installer and select 'Show Packag Contents'
2) Open up MacOS folder and launch the installer - this will open a terminal window where you can see the progress of the installer... note when it finishes you will see the message: "installer: This package requires Rosetta 2 to be installed. Please install Rosetta 2 and then try again."
3) Open new terminal window and ype (or copy paste)  '
sudo softwareupdate --install-rosetta'
4) once this has installe, re-run the installer, but make sure you select 'Open usiong Rosetta' from the Info window of the installer before you launch.
Hope that helps - worked for meScreenshot 2025-02-20 at 09.54.41.pngScreenshot 2025-02-20 at 09.54.51.pngScreenshot 2025-02-20 at 09.55.27.pngScreenshot 2025-02-20 at 10.00.53.png
This message was authored by Chrisannesam This message was authored by: Chrisannesam
Hi. Thanks for the reply.
I followed your steps.
The process completes sucessfully.  I have no issues with missing components.
SkyGo still refuses to open when the icon is clicked.
C
Hi C
Not sure what to suggest mate - did you delete any existing application?
Are you sure, you are trying to open the right app now? Do a search in your finder for Sky Go... i've just noticed my 'App icon' doesnt display in the 'Applications' folder, its in my 'account' folder (users > XXXXXXX > Applications > Sky GoScreenshot 2025-03-03 at 11.09.06.png
On average, new discussions are replied to by our users within 3.6 hours
