This discussion topic has been answered Discussion topic: Sky Go not working (Error 001)
Message posted on 19 Feb 2025 11:08 AM
Re: Sky Go not working (Error 001)
I'm having the exact same problem and error message with a Windows 10 laptop. Ive tried deleting/reinstalling but still the same. Can anyone help an old Windows user please?
Message posted on 19 Feb 2025 08:11 PM
HELP!!!!!
I have the latest mac upgrade 14.6 and SKY GO APP WON'T WORK still getting the error message, where can i find the sky go app latest donwload as the one on there site https://www.sky.com/pages/sky-go/download-the-app is the old one
Message posted on 19 Feb 2025 08:22 PM
Further up this page is one marked as the answer that is working for some.
Message posted on 19 Feb 2025 08:30 PM
Is there a link, still getting error message and i'm using versions 24.1.2
Message posted on 19 Feb 2025 08:33 PM
Can you not see this post:
https://helpforum.sky.com/t5/Sky-Go/Sky-Go-not-working-Error-001/m-p/4751296/highlight/true#M138414
Message posted on 19 Feb 2025 08:41 PM
I did all that and still no help. The only thing that change was i now have the 25.1.2 version but still the error message
Message posted on 19 Feb 2025 09:09 PM
Blimey It worked perfectly. Thank you so much. I have been trying to resolve this for a year.
Message posted on 13 Mar 2025 01:48 PM
Bob on Bob. Works perfectly
Message posted on 20 Mar 2025 11:27 PM
worked perfectly, thank you
Message posted on 20 Mar 2025 11:44 PM
thanks, it worked!!!
Message posted on 21 Mar 2025 04:57 AM
Thank you so much for your suggestion. It worked perfectly. Your's was the easiest and clearest method . Super grateful for your help. I got a little cofused and made a reply attributing this to the wrong community member. I will try to delete it if I find it!
Message posted on 21 Mar 2025 05:00 AM
AMENDMENT In fact it was community member DAGW92' suggestion that I used to get the errant sky go back.
Message posted on 21 Mar 2025 01:25 PM
Thanks for the suggestion. I can see the Sky go folder, and when I open it theres another folder called blob storage, what I cant see is the folder 'web storage'. Any idea as i dont want to delete folders that are needed?
Message posted on 21 Mar 2025 02:33 PM
I saw the blob storage thing but have no idea if web storage came up last. In a frenzy I deleted everything tbh. Hopefully wonder kid @DAGW92 will respond They really need a round of applause! 🙂 👏
Message posted on 22 Mar 2025 11:21 AM
Hi, Thanks so much for that. After countless attempts your advice workerd first tiome. ***** 5 STARS
