51
This discussion topic has been answered Discussion topic: Sky Go not working (Error 001)
This message was authored by: DAGW92
Re: Sky Go not working (Error 001)
Hi Martin,
Sorry to hear you're still struggling with the issue. I offered the Blob_Storage and Web_Storage purely as an anecdotal wayfinder; it doesn't really matter what the folders are called inside the main folder, the main thing is to move the contents to the trash.
What seems to happen is that when Sky Go starts up, if the folder is empty, Sky Go is forced to recreate the folders, and in so doing the app is able to refresh itself.
Give it a try and I think you'll be fine ☺️ Good luck.
I'm glad the fix is continuing to help people 🙌
Hopefully Sky can release an update in future to stop people running into this issue.
This message was authored by: Leo+Wakeling
Hi, All good now. Thanks for your advice
This message was authored by: Martin+F+Green
Just applied the changes as instructed and its now working.  Youre a genius DAGW92, thank you for your support.
This message was authored by: DavidB10
Re: Sky go download not working on mac m2 Sequoia
I have exactly the same problem and would welcome some advice from someone please
David
I'm having exactly the same problem - did you get a solution yet?
Please forward the solution if you can
Many thanks
David
Thank you very much - very helpful!
This message was authored by: LaraVaio
worked 100%. Thank you
This message was authored by: AntPkr
Thank you!
This message was authored by: Dean138
Hi,
I am trying to download sky go on my new mac running macOS Sequoia, i download the sky installer and then run the download but once complete it just dissapers, please can you help? is sky go even available on MAC anymore.
@Dean138
Have you tried what appears to be working for everyone else namely this post that has been marked as the answer:
https://helpforum.sky.com/t5/Sky-Go/Sky-Go-not-working-Error-001/m-p/4751296#M138414
This message was authored by: GeordieLad1950
Re: Sky Go not working on Macbook Air (M3, 2024 Sequoia 15.3)
I'm having the problem. Have downloaded but getting the same message I.e.'we're having problems connecting you. Please try again (0001). Please help and advise
@GeordieLad1950
Have you seen what is in the post above yours ?
All sorted
This message was authored by: Tom284
Fantastic, worked first time. Many thanks!
This message was authored by: jlgoodwin
It would be really _really_ helpful for Sky to update their Error Codes page to include this guidance. I spent the best part of an hour this morning on a new Macbook migration where the SkyGo app wasn't working and no guidance fitted.
These steps (logically for those of us who work with computers) worked a charm and now Sky Go is up and running again!
Answered - Go to Answer
