16 Apr 2024 04:25 PM - last edited: 17 Apr 2024 11:59 AM
Posted by a Sky employeeHey all,
Thank you letting us know about the missing sport channels on Sky Go! We have escalated the problem to the right team, and will let you know as soon as we have more updates about it.
I do apologies for the inconvenience that this causes for all the sports fans, we will try to fix it asap and keep you updated!
I will mark this post as "Answer" only temporarily, and will keep changing it to the newest updates, so everyone can find it easily.
Thank you again, for telling us about the issue!
**Update: Our specialist team is working on the problem. In the meantime you should be able to access the channels on both Sky Go and Glass/Stream by using All Channels.
Community Moderator
16 Apr 2024 05:14 PM
Hi I have also lost various sky sports channels on sky stream not just sky go.
16 Apr 2024 05:16 PM
Posted by a Superuser, not a Sky employee. Find out more@Rachw1 Try restarting the stream device if you haven't already done so
16 Apr 2024 05:34 PM
Already done. I can still watch the channels but they're not on the TV guide.
16 Apr 2024 06:04 PM
Posted by a Superuser, not a Sky employee. Find out moreIf you are using a mobile or a tablet then try installing the Sky Sports app as the Tennis channels appears via here for me.
16 Apr 2024 06:50 PM
Hello I have lost most of my sports channels on sky stream and sky go. Is anyone else suffering with this problem please thanks
16 Apr 2024 06:52 PM
I'm missing most of my sports channels on sky stream and on sky go. Anyone can help please
16 Apr 2024 07:48 PM
Posted by a Superuser, not a Sky employee. Find out more@Jacob21 See the post marked as the answer Here for the latest information
16 Apr 2024 08:49 PM
Posted by a Superuser, not a Sky employee. Find out moreI've discovered that all the sports channels are listed correctly when all channels are listed it's only when you select sports only where they are missing
cc @Kelsingra
16 Apr 2024 09:47 PM
Posted by a Superuser, not a Sky employee. Find out moreIt is also there if you select HD.
17 Apr 2024 09:15 AM
The tennis channel is still missing on Sky Go 17 April
17 Apr 2024 10:21 AM
Posted by a Superuser, not a Sky employee. Find out moreHave you seen the post above and selected All at the top of the TV Guide and you might then find it.
17 Apr 2024 12:10 PM
Thank you for your patience!
Our specialist team is still working on the issue. I just wanted to give you some updates that in the meantime you should be able to access the channels on both Sky Go and Glass/Stream by using All Channels.
Community Moderator
17 Apr 2024 01:23 PM
This is still not working on Sky Go. Having to resort to try and watch on Sky Sports App on phone. Any idea of when an update is expected?
17 Apr 2024 01:27 PM
Posted by a Superuser, not a Sky employee. Find out moreDid try what has been posted above and changed sports at the top of the guide to All ?
On average, new discussions are replied to by our users within 3.6 hours
