05 Apr 2023 08:24 PM
How do I access sky go error code 3-22
06 Apr 2023 05:47 AM
Posted by a Superuser, not a Sky employee. Find out moreTurn the Wi-Fi or data connection off on your device then delete the app and reboot your device. When it has loaded back up turn the Wi-Fi or data connection back on and install the app again.
21 Apr 2023 08:41 PM
I have the same message every time I try using sky go (error 3-22) I have tried all the suggested fixes cleared cache and data reinstalled the app rebooted my device and none have worked! Why is this still happening?
16 May 2023 10:04 PM
20 Jul 2023 12:38 PM
Have tried all the above, no joy! Would it be possible for a memeber of Sky to advise, as they must monitor the site!!!!
22 Oct 2023 09:48 PM
Tried above soln and STILL missing the US GP
Come on SKY..get this sorted...
Why is this app ALWAYS THE most oft uninstall re installed app.?
I just want to watch the GP before someone tells me the result(
27 Oct 2023 10:28 AM
1. Switch off Wi-Fi
2. Turn On Mobile Data
3. start Sky Go
4. Switch on Wifi
5. Switch Off Mobile Data
27 Oct 2023 10:31 AM
1. Exit Sky Go
2.Switch off WiFi
3. Turn on Mobile data
4. Start Sky Go
5. Start your channel
5. Switch Off Wifi
06 Mar 2024 07:48 PM
Did what was said and all up and running now, thanks
05 Apr 2024 10:45 AM
I can't follow these steps as on tablet so no mobile data??
15 Apr 2024 09:22 AM
I am now getting this problem. It used to be fine but I uninstalled it to make space, now I've re installed it and keep getting this is no longer available error 3-22 on every channel I try to watch live
15 Apr 2024 09:29 AM
Sorry for double post.(can't edit)
Is it because I'm using a sky mobile hotspot.? I noticed someone said to put mobile data off. All though it used to work with sky mobile
On average, new discussions are replied to by our users within 3.6 hours
