17
This discussion topic has been answered Discussion topic: Volume Indicator Issue on QS039 update
This message was authored by: Jporch316
Has anyone's volume indicator started acting weirdly since the update ?
if I move the volume up or down the indicator bar sometimes jumps or down after the press ......
also noticed watching a show on U demand that the picture keeps losing focus then refocusing as if it's buffering then catching up
Moderator note: subject of thread updated to better reflect the conversation
This message was authored by: KevNewMedia Answer
Re: Volume Indicator Issue on QS039 update
Posted by a Sky employee
Hi Everyone,
@Jporch316 @mrwwt @Neil+Essex @groupcaptain
Our support teams have advised that this problem has been resolved in UI 3.134
I'm going to mark this post as the current answer so that everyone has the most up-to-date information.
Kev
Community Manager
This message was authored by: groupcaptain
Re: SKY OS 39 Update
Now you mention it, yes. Trying to make small changes by briefly touching the button has no effect; it seems to need to be held down for a period and then moves more than I'd want it to. Replacement GTV due tomorrow.
Avatar for Jporch316
Level 14 icon
Thanks for checking ! Thought my remote was starting to give up .......
This message was authored by: Neil+Essex
Volume indicator bug. Finally someone else who's got this bug. I've had it for a week now . Needs a fix @Jporch316 .
Sky Q 1TB UHD HDR Box & 1 Mini Box
Sky Signature with Netflix
Sky Sports Complete Pack
Sky Cinema
Sky HD & UHD
Sky Multiscreen
TNT Sports
Virgin Media Broadband Gig1
MUTV
Hi Everyone
Thank you for reporting this issue and for tagging us @Jporch316
I've moved your posts to this new thread, so it's easier to track this problem.
Kev
Community Manager
This message was authored by: mrwwt
Yep got this as well,
Hi Everyone,
Kev
Community Manager
Thanks. I've just recevied a replacement Sky Gkass Air and the UI is 3.44.2 By the look of the number, it is later than 3.134 or does it not work like that?
Do you still have the problem on this new TV? Can you send me a PM with your Ethernet MAC address, so I can check that out for you please @groupcaptain
Kev
Community Manager
@KevNewMedia @I'm still on 3.117.3
how do I get the new ui version
Sky Cinema
Sky HD & UHD
Sky Multiscreen
TNT Sports
MUTV
@Neil+Essex There's nothing for you to do as it's a gradual roll-out. There isn't a way to push you onto that release yet, but it should be with everyone in the coming weeks.
Kev
Community Manager
Thanks. My question was simply whether the UI in my replacement is more recent than the one you mentioned. The volume seems fine so far.
@KevNewMedia @Ok many thanks
Sky Cinema
Sky HD & UHD
Sky Multiscreen
TNT Sports
MUTV
@KevNewMedia This morning I see 3.117.3 is the UI. Seems to be working fine.
I'm a bit confused, you said here that your Air had 3.44.2, is that not the case? I can't say why it's not impacting you right now, however, you may find that it comes back until you get 3.134, which is the confirmed fix release 🙂
Kev
Community Manager
Answered - Go to Answer
