18
This discussion topic has been answered Discussion topic: Technical fault
This message was authored by: Paul+Dray
Re: Technical fault
@Mike399 wrote:
Where do you find UI number?
Settings | System management | System info
UI version is the 6th row down in the details.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck: Sky OS 1.3; Build QS040.058.00P; UI 3.301.2; Platform Version 8.4p58s1 | Sky Broadband Superfast
This message was authored by: Mike399
Re: Technical fault
Got it cheers.
This message was authored by: Nickynoodles40
Re: Technical fault
Still can't get any tv
This message was authored by: Mw681
Re: Technical fault
I have had this fault many times and now got subtitles appearing in the middle of the screen without activating them ,freezing programs , programs that keep repeating the last 5 seconds over and over and was told it's my internet that's at fault  . So  as I'm told the broadband controls the subtitles on my tv and controls the software faults can sky please get together with them and discuss sorting their own software upgrades and allow me to control my own tv with my own remote without needing help from the broadband provider thanks
Answered - Go to Answer
