18
This discussion topic has been answered Discussion topic: Technical fault
This message was authored by: Waydon1-
Technical fault
'Please wait for your programme to load' TV then turns off and back on again with same message displayed. Internet connection is excellent, tried switching off and back on again. Can anyone advise what to do?
Avatar for Waydon1-
This message was authored by: Waydon1- Answer
Re: Technical fault
It seems to have corrected itself now, it had been persistent for 24 hours.  Thanks for your help 😊
Re: Technical fault
@Waydon1-  How is your glass tv connecting to your router, what speed is being received at the tv.  Are you connecting over wifi or ethernet?
Open netflix on the TV, go to Get Help, run connection test.
What speed is showing here
Avatar for Waydon1-
Re: Technical fault
Hiya, connected via wifi, connection speed 134.97mbps
Re: Technical fault
@Waydon1-  Speeds are more then adequate, Is this happening when first turning on your Glass TV or during watching something?
Avatar for Waydon1-
Re: Technical fault
This message was authored by: Andy-H2
Re: Technical fault
Been happening here too all day, impossible to watch the golf thought this issue would have been sorted after the last outage on Q and switching to Glass grrrr
Avatar for Waydon1-
Re: Technical fault
It was the golf that I wanted to watch too, really frustrating 😡
This message was authored by: Jporch316
Re: Technical fault
Seems to be happening to a few judging by the handful of posts on the forum today
Re: Technical fault
@Jporch316  It happened to me this evening at 9pm when I went to watch a U&Alibi programme from my CW rail.  A reboot resolved it as usual.
Re: Technical fault
@Fothergill1  In another thread @Paul+Dray suspects its as a result of a new qs update
This message was authored by: Paul+Dray
Re: Technical fault
Yeah though I've got a Stream Puck not Glass. Seemed to start yesterday when my build changed from Build: QS036.019.00P to QS036.021.01P. It seems to have resolved itself now though today. So not sure what happened.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck: Sky OS 1.3; Build QS040.058.00P; UI 3.301.2; Platform Version 8.4p58s1 | Sky Broadband Superfast
Re: Technical fault
@Jporch316  He might be right.  A few days ago I was on UI 2.30.0 but I noticed earlier today that I am now of UI 2.50.0 but I don't know when the updated happened.
Re: Technical fault
I hadn'tnoticed the Build version has also changed @Paul+Dray but I see I have actually gone backwards.  A week ago my puck was on QS036.023.00P and today I see I am on QS036.021.01P
Re: Technical fault
Yeah I went back a few weeks ago to a lower number build. Not sure the reasons for going backwards as I didn't have any problems.
This message was authored by: Mike399
Re: Technical fault
Where do you find UI number?
