14
This discussion topic has been answered Discussion topic: Sky TV Wall Mounting
This message was authored by: Frieslick
Followed the instructions for wall mounting Sky Glass. We have then hung the TV on the bracket but there are no further instructions. Is it meant to just hang? It's probably right but it just feels like it needs to be bolted or secured but there's no access to do so as it's almost flush to the wall.
Re: Sky TV Wall Mounting
@Frieslick
The set is secured by the lugs on the top edge of the bracket: to be dislodged it would have to be both lifted and tilted backwards, which is incredibly unlikely to happen accidentally.
This message was authored by: Kayzoo123
How do I put a sky glass on a wall, no fittings etc
How do i install a glass tv on the wall there is no fittings etc
This message was authored by: Tim+Adams
Re: How do I put a sky glass on a wall, no fittings etc
Hi @Kayzoo123
The wall mount is included in the package along with spacers.
You need to source your own screws to attach the mount to wall.
https://www.sky.com/help/articles/sky-glass-wall-mounting-guide
Thanks,
Tim
Sky Glass, Sky Stream & Sky Protect - FTTP 2.3Gbps
I don't have that, people from sky come and set it up to go on TV unit but took the packing away?
Hi @Kayzoo123
They should have left you the 4 spacers. The wall mount is actually what attaches the TV to stand, when using it to attach to the wall you dismantle the stand.
Thanks,
Tim
@Kayzoo123 alternstively you can buy a thrird party wall mount. Glass TV have standard mounting points in a 300 x 200 arrangement.
This message was authored by: Padam_Padam
As long as you followed the instructions and the wall you attached the bracket to is strong enough then that's it. Glass is a heavy TV so gravity will hold it onto the bracket.
@Frieslick
This message was authored by: adjdc3009
Does sky have people they send to put sky glass on the wall
No, you need to sort that out yourself.
This message was authored by: John19761
Can someone recommend a good fit to wall mount my sky glass (65)  Also need them to supply the mount as well?
This message was authored by: Whodareswins1
I was going to ask the same question
Thinking of purchasing sky glass
I'm thinking of purchasing sky glass but would like to know if when selecting the fast delivery option where they install and take to room of choice etc does this include wall mounting if I provide the correct bracket,screwdriver etc
Re: Thinking of purchasing sky glass
@Whodareswins1
Have moved your other posting here and removed your duplicate posting.
For your question on delivery, setup and mounting;
The delivery, now from AIT, does not offer setup and wall mounting.
You have to do the setup and mounting yourself or arrange for a third party to mount it.
Delivery Sky help article;
https://www.sky.com/help/home/sky-tv/sky-tv-glass/delivery-and-returns-sky-glass/delivery-sky-glass/...
Wall mounting Sky help article guides;
Ok thats great to know thank you for your response
Answered - Go to Answer
