37
This discussion topic has been answered Discussion topic: Playlist Issues Again
This message was authored by: ScottishClaymore
The Most Recent & Movies section of Playlist is missing but even if I create new Playlist the Movie section disappears on New Playlist
This message was authored by: Kelsingra Answer
Re: Playlist Issues Again
Posted by a Sky employee
Hey all,
Thank you for your feedback and help about this issue! 🙂
Our Technical Team is working on a resolution for the playlist issue. We are expecting an update coming out in the next couple of days. We would really appreciate if you could let us know if your playlist stars to work as expected again by the weekend? 🤞
Thank you for your patience and understanding!
Fanni
Community Moderator
I'd suggest trying a reboot:
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
Avatar for ScottishClaymore
Level 4 icon
@MarkGoldsmith  Tried that and still same , even unplugged it from wall
This message was authored by: TM5
Movies not showing on my playlist
For 3 days now I have seen that movies are missing (sky cinema) on my playlist and I can't record any. Have tried unplugging sky Glass, and rebooting but nothing works. I have checked my account and Sky Cinema is still active. Is there anything else I can try please?
This message was authored by: andrew1990-1990
Re: Movies not showing on my playlist
I am having the same problem .. My playlist is no longer showing any movies .. However i have found them under the movies section along from the playlist selection .. If you scroll down a few lines they are found there .. Hopefully this isnt a permanent feature
I have also tried this but still nothing .. Ive noticed the most recent section is also gone
This message was authored by: soniac75
I've also got this problem
This message was authored by: Anthony+j1
Sky glass playlist
Sky glass playlist not showing movies stored, or allowing new movies to be saved, just set “set to record" but nothing saves. I have subscription to movies.
ive reset sky glass, didnt change it
This message was authored by: CoffeeDrinker
Re: Sky glass playlist
Are you adding films to the playlist from the TV guide or from the Movies tab at the top of the Home Screen?
the former won't add anything until that particular transmission, the latter is all the on-demand films and can be added and/or viewed anytime.
Sky Glass & Stream Puck customer w/Sky Ultimate & Netflix, Sky Cinema, Whole Home & UHD/Dolby Atmos add-on.
Hi.
tried both, no joy with either
Anything added to your playlist will still be there under Playlists --> Manage All, everything will be there that was added to your playlist including any recently added movies.
Not ideal I know however this work around should let you find your playlisted movies for now.
Marking this workaround as Answer untuil we get any updates from Sky themselves.
Hey all,
Welcome to the Community Forum and thank you for letting us know about this issue!
We would appreciate if you could give use some more information about the fault:
  • do you experience it on your personalised or on your main playlist?
  • can you please tell us an accurate time when you experienced it?
I will pass these details to our Technical Team to find out what is causing the issue 🙂
Thanks,
Fanni
Community Moderator
Level 4 icon
I am experiencing issues with Personalised playlist & Main playlist, I've had issues since 2nd July around afternoon
I'm only having issues with my personalised playlist.  The main playlist still shows movies.  The problem started sometime since Thursday.
My issue is only with the main playlist (Which is all i use) .. However i have added a new profile as a test and this is working fine
