This discussion topic has been answered Discussion topic: Playlist Issues Again
Message posted on 08 Jul 2024 02:50 PM
Re: Playlist Issues Again
Oh and i noticed this on thursay .. 🙂
Message posted on 08 Jul 2024 07:22 PM
Issues with playlist
Hi guys. Does anyone know when the issue may be sorted with regards to the most recent tab in playlist section of stream. Its a bit annoying having to go a-z through tv shows tab. Cheers
Message posted on 09 Jul 2024 03:04 PM
Is there any update on this from SKY?
Message posted on 09 Jul 2024 06:52 PM
I am having the same issue even after numerous reboots, on the main and on all profile playlists
Message posted on 09 Jul 2024 06:55 PM
@andrew1990-1990 Updates will be posted as soon as there is any.
Message posted on 11 Jul 2024 08:36 PM
Playlist - movie rail disappeared
Anyone else having an issue?
Under my playlist the movie rail has disappeared. Only way I can view it is by going into the movies tab and viewing the playlist from there.
Message posted on 13 Jul 2024 04:43 PM
Movie playlist missing
On sky stream my movie playlist has dissapeared. Reboot does not bring it back.
series are still there
Message posted on 13 Jul 2024 06:34 PM
Re: Movie playlist missing
Movies and recent has vanished from playlist. Been about a week now. Anyone any idea?
Message posted on 14 Jul 2024 05:35 PM
I created another playlist yesterday and when I added a movie to that playlist it displays perfectly as it used to.
seems the default playlist still has a bug with no fix been deployed to the pucks yet.
Message posted on 14 Jul 2024 08:57 PM
Re: Playlist - movie rail disappeared
Hi I seem to be having the same issue as most, my personal playlist has only the TV section and the others have all, go into manage and they are all there but every time I add a film it's not showing on MY playlist. Has any one received a reply? Problem been ongoing from Fri (when I just realised)
Message posted on 15 Jul 2024 06:45 PM
Turned sky stream on this morning and yet again and my movie playlists is missing click on it and get a list of TV Shows not movies , do not have playlust called TV shows. playlist . Always seems to be the final playlist , movies, that vanishes . Rebooting does not resolve . Yes it I lookat all orog mivues do show as being in list . Sky having yet more issues with stream ??
Message posted on 16 Jul 2024 03:15 PM
I am also experiencing this issue on the main playlist and individual playlists as well.
Been happening for a while now, only work around is to go to manage all and play from there.
Message posted on 16 Jul 2024 03:22 PM
I haven't bothered contacting Sky as I see many people have the issue so I assume they are aware . Happened a while ago and seemed to be resolved after a couple of days .
Message posted on 16 Jul 2024 03:26 PM
Haven't seen a resolution yet, been about 2 weeks now at least...like you haven't contacted Sky as it seems to be a known issue. I assume they are aware and will release an update soon.
Message posted on 17 Jul 2024 01:06 PM
Just gave in and rang Sky , wanted to discuss my ever increasing bill anyway , they are aware of the playlist issue but asked that as many people as possible ring in and let them know so they can gather evidence to try and diagnose the issue better
