29
This discussion topic has been answered Discussion topic: No tv guide or live tv
This message was authored by: Natalie109
Got up this morning to put BBC Breakfast on as I do every morning and there is no tv guide or live tv at all. I have rebooted the tv and broadband about 3 times and still nothing. Tried voicing various channels and nothing.
This message was authored by: KevNewMedia Answer
Re: No tv guide or live tv
Posted by a Sky employee
Hi @Natalie109 @Paul84-_
Thank you for highlighting the problem that you've been having with your TV/puck.
1. Switch the TV/puck to standby and unplug from the wall socket.
2. Plug it back in and make sure you leave it for at least 15 minutes in use, or on standby.
3. Put the TV/puck back on to standby, and then switch off at the plug. There's no need to unplug from the wall this time.
4. Switch on and check to see if the issue is resolved.
Can you let me know how you get on afterwards please? @Natalie109 @Paul84-_
Kev
Community Manager
When you say rebooted TV, have you tried the restart in your Sky Glass TV settings.
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Glass will perform a reboot. It will take a few minutes to complete
Hi @Natalie109 is there any messages on screen? Do you have an active Sky TV subscription?
This message was authored by: LMcN2
This same problem for me. I've rebooted through sky glass and turned off and rebooted etc. still nothing. Voice activation brings blank tv guide just times no info. All apps appear to be there
Interesting! I wonder if there's an outage for some atm.
Can you try a you restart within the Sky Glass settings, rather than a power off restart
Your Sky Stream Glass Tv will perform a reboot. It will take a few minutes to complete
I’ve done both restarts, still no change
@LMcN2
Can you remove the power or switch off at the switch your Sky Glass TV.
Reboot your router.
Once your router is back and working, wait about ten minutes, power on your Sky Glass TV, let it rest  on the home menu for a few minutes, no longer.
Once again do a restart from settings on your Sky Gkass TV, not a power reboot.
Wait a few minutes, no longer and try the tv guide and live channels again.
I've rebooted the router twice also. Still nothing
@LMcN2
I've escalated this to Sky and they should be in touch with you soon about it.
Look out for a message from Sky on your email and Sky Community private messages.
Look out for the blue chat bubble within your Sky community.
More about an escalation here;
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite LMcN2.
This message was authored by: Paul84-_
I've tried all that as well and still nothing, it's pretty frustrating to be honest I wonder if its glass TV out of warranty
This message was authored by: nogimmix
This morning, the Cityfibre network is having issues which will affected any Sky Glass connection, if you are on that network.
Who is your broadband with?
@Paul84-_ I suspect there's a service issue because a few people have raised it.
Avatar for Natalie109
I have rebooted as suggested and still nothing
