Discussion topic: Sound glass tv
Message posted on 22 Nov 2024 01:55 PM
Re: Sound glass tv
@Sonia14 wrote:It was faulty from day one so yes they was aware of it
Definitely speak to them again. Lodge a formal complaint if you continue to have difficulty getting a fully functioning set.
Message posted on 22 Nov 2024 01:56 PM
Re: Sound glass tv
@Sonia14 Was it replaced during the cooling off period?
Message posted on 22 Nov 2024 01:58 PM
Re: Sound glass tv
I am so disappointed in this had nothing but issues.when they brought the new tv they didn't put the new stand on what came with it left the old one on so it was a different white to the tv.So had to put a complaint in over that .
Now this new tv with the sound issue fed up .
Message posted on 22 Nov 2024 05:37 PM
Re: Sound glass tv
@Sonia14 Are you still in your cooling off period?
Message posted on 22 Nov 2024 06:06 PM
Re: Sound glass tv
Does it start again if this is a second tv ?
Message posted on 22 Nov 2024 07:10 PM - last edited: 22 Nov 2024 07:35 PM
Re: Sound glass tv
The right to reject Glass as a product without giving a reason doesn't restart: under consumer protection rights that only applies to the initial unit.
You can insist on another hardware swap though: chances are you've received a refurbished unit and it's possible they missed an actual fault.
Message posted on 22 Nov 2024 07:11 PM
Re: Sound glass tv
Thank you
